96 GMC Jimmyjaydeline 07-30-2007, 10:15 AM My jimmy was running fine yesterday, started right up. I went down a dirt back road, where there were some ruts,(wash out ruts I guess), Anyway, I was driving, I slowed down, as no way to avert them, then my engine just quit. I went to start it again, and the fuel pump wouldnt kick on. I checked all fuses and nothing. All were good. someone told me to check the fuel pump relay in the glove box. I tried it and still nothing. what could have happened???? Ok someone said to check the inertia switch. I have some mechanics telling me that GMC dont have them then another says they do. If they do, where is located????? would someone email me please? I need this vehicle to get to work Thanks whataboutme88@yahool.com MT-2500 07-30-2007, 01:10 PM W3elcome to AF. Only Fords have inertia switches.:grinyes: It is not wise to post your e mail for the public to see. Any answers here you can read and should get a e mail notification when a answer is posted. Fuel pump relay behind glove box. Check EMC fuse no 5 for power. Check gray wire from relay to fuel pump for 12 volt power. Key on 3 second fuel pump prime or starting. Also there is a single red fuel pump prime wire someplace for testing fuel pump. jaydeline 07-31-2007, 10:35 AM ok sorry, I switched around all the relay switches and nothing worked. MT-2500 07-31-2007, 01:22 PM ok sorry, I switched around all the relay switches and nothing worked. Check EMC fuse no 5 for power. Check gray wire from relay to fuel pump for 12 volt power. Key on 3 second fuel pump prime or starting. Also there is a single red fuel pump prime wire someplace for testing fuel pump. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
