98 Blazer no a/c light flashes 3 times
Google
Web AF
98 Sonoma
07-29-2007, 11:18 AM
I have a friend with a 98 Blazer with Comp.ClimateControl, the A/C light flases three times but won't engage. I tried different combos of control settings. What am I missing?
MT-2500
07-29-2007, 12:23 PM
Is the system full of R-134a?
You can read codes with a good engine/body capable scanner.
Has anything been done to or changed on sytem?
98 Sonoma
07-29-2007, 08:14 PM
I don't know if it's charged yet or if anything was changed. The manual says if it flashes three times one of the control settings is wrong but I tried several combinations. Would the system reconize low R134A? Something is not giving it the okay to engage thus no compressor clutch engagement.
Thanks.
MT-2500
07-30-2007, 09:51 AM
Yes a body/AC capable scanner will set and read codes and tell you the problem.
Get code and post back code.
Or you can check R-134a charge.
With compressor jumped and running post back you low and high side readings at idle and at 2K.
With a ac recharging gauge set.
Like one of these.
http://www.ackits.com/merchant.mvc?Screen=CTGY&Store_Code=01&Category_Code=RefrigerantGaugeSets
http://www.ackits.com/merchant.mvc?S...ory_Co de=DIY
Google
Web AF
