Stuttering when barely hitting gasCaptainTrips 07-28-2007, 08:13 PM I have fixed everything on this 93 corsica i got and it runs great, but when i try to maintain speed and am barely pressing on the gas it will jerk, but runs great if i let off the gas or press harder and start accelerating. its a 93 corsica with a 3.1L 6Cyl Engine. I have replaced the throttle position sensor and the fuel filter. what could be causing this? I figure if it were the fuel injectors it would happen idle or accelerting.... any ideas? TIA CaptainTrips 08-01-2007, 11:14 AM I just had a friend say it could be an automatic transmisison issue, but I dont really know what aside from a tranny problem could cause this and how it can be fixed, and im broke so taking it to a shop is out of the question for now, aside from changing the fluid. what could i do on my own? tabernacle tranz 08-01-2007, 11:12 PM is it a 3 speed with lock up or 4 speed? if its a 3 speed try to unplug the plug in the front of the trans then drive ,if the problem goes away its in the tcc switch if its a 4 speed try this when the problem happens try putting your foot on the brake ( very lite )see the problem goes away.tryeather one of these CaptainTrips 08-06-2007, 07:38 PM Well. its an automatic.. and I have noticed the engine moves quite a bit when i shift, maybe a broken mount? i have tried to see for myself but im fairly new to working on cars and cant find them.. is there a diagram somewhere that would show me? esrman 03-24-2009, 12:35 PM I had the same problem. It was a broken rocker arm stud. A trip to the junk yard yielded a used one and that cured it for about a week! Then the same rocker arm came loose,yes I torqued it. Torqueing again solved the problem,I hope. its been 2 weeks now. Take a cylinder compression chek. The bad stud or rocker arm will show,as that cylinder will have absolutely NO compression. Another clue would be that it des not idle smoothly. rhandwor 03-26-2009, 07:51 PM A lot of Chevy rocker arm nuts are lock nuts. If it comes loose again use a new lock nut. If the stud is coming loose use lock tight. esrman 03-26-2009, 09:16 PM I just had another stud break. Are these a prob with the 1994 Corsica? I replaced it but am worried another one will break. That`s 3 so far. Should I replace all the rest? I also have one cylinder,naturally in the back,where the tappet is noisy. Its not a loose rocker arm as I checked it when I took it apart yesterday. That leaves either a lifter,bent pushrod,or,(here it comes!),the cam`s rounded out. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
