93 s-10 blazer signal lights won't work
Google
Web AF
millertime40
07-28-2007, 12:59 PM
My singnal lights stopped working and i need help :banghead: and i'm having trouble with 4-wheel drive-drive shaft:runaround:
MT-2500
07-28-2007, 01:10 PM
Welcome to AF
Please give us a little more info?
So we can better help you.
What kind of drive shaft trouble?
What is it doing or not doing?
What are the signals doing or not doing?
MT
millertime40
07-30-2007, 04:10 PM
The signal lights use to work until we started hauling things in it...they wont work at all except when you turn the right signal on then both blinks .I don't know what is going on with them.....as for the 4-wheel drive i think it might be warped or the other drive shaft might be bad someone told me it could be warped cause when i drive my blazer it vibrates the whole vechicle.I wished i knew more about things like that........:banghead:
MT-2500
07-30-2007, 07:20 PM
On the drive shaft check u jounts and splines on shaft slip joints.
The turn signals I would drop steering column splash cover and find the turn signal wiring plug.
The check for what is going into and coming out of turn signal switch.
Make sure 4 way switch is not stuck on to.
Also a trailor light plug and add on wiring for it can be bad or shorting across to.
Dark green wire is right turn and stop light and yellow wire is left turn and stop light.
Go for them and see what you have.
MT
Google
Web AF
