:( water in my cylinder1969NovaSS 07-26-2007, 11:47 PM well i finally cranked my engine and i did it without the plugs in and some water came out off the #7 cylinder and im praying its just a leaky intake gasket but im not SURE so where should i start and whats the most common cause of water gettin into a cylinder? also i read that you should use a good amount of gasket maker on the intake just for this reason and i used some but i didnt know i should put any more than wat seemed reasonable so if someone can help me out THANK YOU :banghead: exoticars07 08-01-2007, 12:44 PM well... if you think you have an intake problem. check your oil make sure there is no water in there and then go ahead and do a coolant test. and if everything checks good then you could have just got water in the carb and ur number seven intake was open. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
