91 sonoma starts, but sputters out, see if you can figure this one out!!
Google
Web AF
dcemmett
07-26-2007, 05:59 PM
I have a 1991 GMC sonoma 2.8LV6 with 194,000 miles on it. I was driving on the interstate on saturday and it died suddenly. There is 3/4 tank of gas. It will turn over and start, but won't run unless I pour gas in the throttle body, then it runs smooth. Everyone around here is stumped considering what has been checked/replaced, which is:
new fuel pump 1 month ago
new pickup coil, ignition module, rotor and cap 1 month ago
another new ignition module 1 day ago
new fuel filter 3 days ago
new fuel pressure regulator 1 day ago
checked wiring around ECM/Dist, no breaks or loose wires
checked fuel relay, works well
installed new injectors, didn't make a difference, so put old ones back
checked and cleaned all fuel passages in throttle body and fuel lines
The injectors are spraying a light mist, but it does not keep the engine going, unless I pour gas in the throttle body. We have checked electrical and physical fuel delivery systems, and cannot figure this one out. I am 500 miles from home(at a friend's) and my mechanic, but on the phone, he can't figure it out either.
Could the fuel pump be bad? It hums when the ignition is turned, and fuel is getting up to the engine, just seems like not enough? Thanks for any opinions/advice!! If you know the problem, feel free to give me a call, 334-414-0141, I need to get this back on the road ASAP!
blazes9395
07-27-2007, 11:41 AM
Check your fuel pressure. You need it to be at spec for the system to work right. Just because the fuel pump is humming, doesn't mean its working right.
Rick Norwood
07-27-2007, 02:52 PM
Absolutely, blazes9395. If this is similar to my old '89, you could look into the top of the throttle body and pump the lever and you should see a lot more than a fine mist coming out of the injectors. A pressure check is your next step.
Google
Web AF
