1973 Karmann Ghia 1600 cc engineCortnyspapa 11-09-2002, 01:15 PM My TRIKE has a 1973 Karmann Ghia 1600 cc engine and just recently it started back firing, I have replace plugs, points, cap, wires and adjusted valves. If anyone can give me another suggestion please do so. Drfthis 02-26-2003, 09:21 PM your carb Axman 06-11-2003, 11:32 PM Yes, check the carb but make sure the exhaust doesn't leak. Is the engine missing if so then check or replace the carb. You can get a rebuilt one for under $100. bedlamite 07-15-2003, 09:44 AM More info would help, what carb is it? 30 PICT or 34 PICT-3, and what distributor do you have? What RPM /throttle position is it backfiring? It's possible you have a clogged jet, loose intake boot, or a leaking vacuum line. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
