Neutral Safety Switch
Google
Web AF
FleshGear479
07-26-2007, 12:55 AM
Okay i have a 94 Blazer 4x4 4.3w and the neutral safety switch is located on the steering coloum and it's a ratcheting neautral safety switch... but i need to know is there anything special i have to do to install the neutral saftey switch? or do i just leave it in park and pop the new one on and hook up the wires? i already have the old one off....:evillol:
MT-2500
07-26-2007, 09:40 AM
You need to stay with the first post you started.
Did you check it out to be sure that is the problem?
There is a slide adjustment on them where the screws bolt it down.
You adjust by sliding it to it where the starter works in neutral or park position.
MT
FleshGear479
07-26-2007, 10:41 AM
there are no bolts or anything on my neutral safety switch it just clips in
MT-2500
07-26-2007, 01:08 PM
One that one you will need to set your shift tube prong to line up with the switch slot before clipping it in.
And Take a close look at it for some kind of adjustment.
Good luck
MT
Google
Web AF
