2000 Isuzu Rodeo Timing belt/Tranny question.
Google
Web AF
Rodeojet52
07-24-2007, 06:51 PM
2000 Rodeo 3.2 with 136,000 miles
A few questions about the timing belt.
Is it common for these belts to break on the 3.2?
Is my engine an interferance engine?
What else should be replaced while changing the timing belt?
Tranny question.
How do I check the level/condition of the transmission fluid?
surferfletch
07-24-2007, 07:13 PM
Did you break the belt?
It's not uncommon to get 100K + out of the belt. It is an interference engine. You should change the belt, water pump, tensioner and its pulley, idler pulley.
You check the tranny fluid level with the higher of the 2 plugs on the bottom of the tranny pan. You start it cold, let it idle a couple of minutes, put the truck in N, pull the top plug. If a little trickles out, the level is good. If none comes out, you pump in some fluid until it starts leaking out and replace the plug. Loads of info available if you search.
surferfletch
07-24-2007, 07:29 PM
http://i104.photobucket.com/albums/m200/McKee_62/rodeotiming1.jpg
I like posting this pic whenever timing comes up...
Ramblin Fever
07-24-2007, 07:55 PM
It is an interference engine. .
Hey Surf, think you may have mis-worded....maybe, or has it been proven that the 3.2L IS interference.
Just double checking.
trooperbc
07-24-2007, 08:12 PM
it is NONinterference.
which will give you a little reassurance, but you don't want to wait, cause it can cause other damage, like to the tb covers. not to mention, the water pump is done at the same time (recommended) and if yours hasn't been done, the wp can seize and cause tb problems among other things.
hth
//bc
surferfletch
07-24-2007, 09:14 PM
Just plain wrong, I guess. I thought we had posters with valve damage following a timing belt break...
surferfletch
07-24-2007, 09:18 PM
I defer to the master...2eyefishclaw...
http://www.automotiveforums.com/vbulletin/showthread.php?t=624425&highlight=interference
surferfletch
07-24-2007, 09:29 PM
See!
[Picture of 4 cyl. with piston damage deleted because it makes the page too wide.]
(Wonders how long before they realize it's a 4 cylinder engine....)
Must have been thinking about this one!
surferfletch
07-24-2007, 09:42 PM
2carpros.com says:
SOHC no
DOHC yes.......
Rodeojet52
07-24-2007, 09:52 PM
The belt isn't broke, just thinking ahead and trying to solve the interferance mystery.
As far as the tranny goes (automatic) I read in the shop manual the fluid gets checked by a temp gauge. Is your way another way of doing it?
Why can't this tranny have a dipstick like all the others in the world?
surferfletch
07-24-2007, 10:11 PM
Yes. I don't have a temp guage. So my method is less exact for sure. I'm sorry for the short, incomplete answers. Searching or reading the manual will help fill in my omissions.
Ramblin Fever
07-25-2007, 12:52 AM
FWIW - Surf, I thought there was a poster at one time, with the 3.2L that had broke his belt and it HAD done damage; so I'm not 100% either, although I believe the experts: JLEMND and 2eyefish clearly state that it's a NON-interference.
OP - agree, don't want until yours breaks before changing it out - 130k is long enough. When you change your timing belt, I highly recommend doing the following as well:
waterpump
timing belt tensioner - VERY IMPORTANT
other accessible coolant hoses/driving belts while everythings available.
thermostat - change with OEM Isuzu ONLY
Flush radiator
Transmission -
Have you ever changed the tranny fluid/filter before??
I hope so, otherwise, you may want to leave it alone at this point - except to add fluid if needed. That 136k mile fluid may be the only thing holding it together - IF it's original fluid, that is.
If you've changed your fluid within the last 40-50k or so, I'd drop the pan, clean it, replace filter and refill.
surferfletch
07-25-2007, 05:50 PM
Just killing time last night!
Google
Web AF
