Loud Noises : VW Type II Pickupcbbond 07-23-2007, 05:21 PM Hello Forum Members: I am still trying to find out what is causing the loud noises on my '58 VW pickup. I have a funny feeling that my problem might be swing axle issue or a bad wheel bearing. When I am going under, say 40mph, I hear a DIT-DIT-DIT sound. But the sound does not appear to coming from engine compartment. Does anyone know how to troubleshoot swing axle and check for loose bolts, etc.? Do I need to take the rubber boots off both sides (near tranny and near wheel)? Please help. Thanks, ginge61 08-19-2008, 07:19 AM check the hub nut they can cause this type of thing very large nut and suposed to be very tight denisond3 09-20-2008, 07:54 PM I would wonder if dit-dit-dit noises could be something from the brakes that was loose inside the drum, and bouncing around. If its a stock swing axle, taking the rubber boots loose wont tell you much. There were lug bolts made for other cars that were the same as those on the VW, except a little longer. If you used one of those on a VW the end of the lug bolt would protrude into the drum, and would be hitting something. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
