20's got some questions
vicls
07-20-2007, 02:09 PM
Okay guys im thinking of getting 20's, my buddy has 20's and seems too drive just fine because of the great air suspension system these cars have. But anyways i see some 20X8.5's which the site says it will fit. Should i get 20X8? Whats a good ride im looking for 20's and yes i understand it will rub sometimes when i hit a bump. So let me know whats a good size.
shorod
07-21-2007, 08:42 AM
Welcome to the forum!
Mentioning you want 20's and asking about a "good ride" is a bit of an oxy moron. With 20's, you'll need a very low profile tire, and that low profile tire will have a pretty stiff sidewall, which will prevent you from getting a good ride.
Also, unless you've modified the suspension on your LS, it does not have air suspension.
And, if you go to 20's, be aware that in addition to adding increased wear on the suspension components (which are not cheap to replace) your braking will also be less effective. I hope you are considering the safety implications of going to 20's rather than just thinking about the bling factor.
-Rod
-Rod
