1996 accord tach jumpstimssail 07-19-2007, 10:31 AM 1996 v6 2.7 tach jumps but not all the time. In gear and in neutral. Is this an electronic sensor or is it physically attached to the engine cam. Bootsgamer 07-19-2007, 11:58 AM yeah its a electronic sensor but i dont know how to fix this problem. jeffcoslacker 07-19-2007, 03:33 PM Stole this from another board.... DTC P0725: Accord V6 Bulletin No. HSN 0899-05 Aug 1999 When you troubleshoot the cause of a fluctuating tachometer or DTC P075 on 95-96 Accord v6 (a code usually associated with an A/T lock-up clutch problem), be aware that the condition could be related to a resistor in the ignition coil. Through the resistor, the TCM (transmission control module) provides electrical pulses that drive the tach. Even though this problem doesn't affect the coil's ignition functions, you'll probably need to replace the coil. (The coil resistor isn't available separately.) The ignition coil is P/N 30520-POG-A02, H/C 4598371. jgr7 07-20-2007, 04:24 PM Here is a link to a thread that I started a few years ago for this problem. http://www.automotiveforums.com/vbulletin/showthread.php?t=187491 Jeff vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
