Brakes
Google
Web AF
makthenif
07-17-2007, 11:11 PM
when i step on the brakes, i noticed that the pedal is getting lower and lower to the floor. what is causing this problem? any thoughts or comments would be appreciated
abaird
07-24-2007, 01:36 PM
Do you mean that if you hold your foot on the brake the pedal seems to fade or keep going down? If so then probably a bad master cylinder.
Davescort97
07-31-2007, 02:46 AM
Bleed the master cyclinder, then bleed at the wheels, farthest from the master cylinder first. If the problem is mechanical rather than hydraulic go to a parking lot and make several stops from reverse and it will adjust the brakes on the rear wheels.
maxwedge
07-31-2007, 07:47 AM
In the future please post year make and model for ease of advice, makes sense, no?
denisond3
07-31-2007, 08:50 AM
If your car has drum brakes on the back, the self adjusters could be stuck. They may not adjust anymore. Its a more common problem with cars over 10 years old.
Google
Web AF
