4L60E 96 s10 into 96 tahoe
Google
Web AF
sexyrex
07-17-2007, 02:27 AM
does any one know if the 60e will fit into the 96 tahoe coming from 95 s10(w)? direct swap or will i have to modify something?
silicon212
07-17-2007, 02:48 AM
Will it fit? Perhaps. Will it last? Not a chance.
sexyrex
07-17-2007, 02:51 AM
what do u mean? arent all the parts the same?
Blue Bowtie
07-17-2007, 10:34 AM
What silicon was hinting at is that the V-6 version possibly (likely) has only 5 clutch discs in the forward (3-4) clutch stack. The V-8 version will likely have 6, and really should have 7 clutch discs and steels.
So, your question can be answered with a qualified "yes" - The parts are the same, but one of the transmissions probably has more of them. There will likely be other subtle differences, and that's IF both transmissions are the same variety, i.e., if they were both designed for 4WD or 2WD.
sexyrex
07-17-2007, 11:28 PM
alright thx alot! i'm probably better off rebuilding than...
wafrederick
07-21-2007, 10:29 AM
The interchange is 1996 only,Looked it up in an interchange book once called a hollander.1995 is by itself too,looked this up in the hollander interchange book too.
sexyrex
07-21-2007, 01:38 PM
UPDATE: transmission is fixed! it was pretty simple. i had no prndl lights, no tach, no speedo, and seemed like it was stuck in third...intermittently transmission would work with an engine restart. googled ignition switch. called the jobber and they actually had one in stock. all working good now!
Google
Web AF
