View Full Version : Tranny Question??
Tranny Question??
<240sx_sr20det>
07-16-2007, 09:20 PM
does anyone know if the sr20det tranny will work with the ka24de motor????
neon2nissan
09-05-2007, 05:07 PM
I Don't know...
However, if you can bolt the jm motor to the usm transmission, it stands to reason the reverse should be true.
Maybe.
don't blame me if you try it, it connects, and then something blows up and sends little hot pieces of metal through you.
badicalradical
09-05-2007, 10:34 PM
For the most part the internals are the same (from what I know) except for the s15 6 speed (same bell housing but with thiner gears to make room for the 6th). As far as your question though, NO. The SR bell housing is different from the KA. Why do you ask though?
AWDSR20
09-06-2007, 03:07 AM
no it will not.
nissan_240sx
09-06-2007, 06:45 AM
agree
no
MetalHeadZaid
09-06-2007, 11:18 AM
didnt somebody do this on nico and post up saying it worked well???
Fla240sx
09-08-2007, 02:23 PM
its not hard to swap bellhousings
you gotta take out all the bolts in the middle of the case halves, where the aluminum parts bolt ot the iron center section, then there are some bolts inside the bellhousing that come off then a snap ring inside that comes off
then u just wiggle that lil SOB bellhousing off..... putting it back together is a lil more difficult because the shifter rails have to be all ligned up.......
still this is a kindergarden type job when it comes to transmissions....
Related Links
Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free.
