99 crv noise
mark5019
07-16-2007, 06:42 PM
when i drive i get a louad whine from rear of crv, only on right hand curves
mark5019
07-18-2007, 01:22 PM
was bad bearings and bad hub
conix
07-22-2007, 03:22 PM
Hi do you think that I have the same problem that you had?
It ( the sound) happens only when I turn the whell all the way (right or left) but not in straight line as far I know. I will pay more attention next time.
the sound is not very loud but noticeable though.
mark5019
07-22-2007, 05:43 PM
it happened only when i made right turns, check the castle nut see if tight
they found mine loose
Gene Vondette
07-22-2007, 05:54 PM
Change your rear differential oil. It costs less than $10 a litre, and the problem will go away in about 5oo miles.
I had the same problem with both my 2001 and 2003 CRV's.
It should be done every 60,000 or so anyway.
mark5019
07-22-2007, 06:04 PM
they found the castle nut loose bad bearings and hub all fixed under warrenty no noise now
