Driver window door control panel not working
laharidas
07-16-2007, 06:12 AM
Hello All
I have a problem with driver side window control panel. Only driver side window glass button is not working properly. The glass is sliding down properly but it is not working properly when I press button to move glass upwards. I need to hold for a long time with more force to do that. Do I need to replace the circuit? ( the black colored box, with button and circuits)
All other butons of the same control panel are functioning fine.
Thanks for looking ..
Have a good day
Lahari
Have a good day
Lahari
methodmix
07-16-2007, 04:39 PM
I actually had this exact same problem with my 00 Altima GLE. You will have to replace your master control module (contains the buttons for window and lock control).
You can extract this part by popping off the plastic covering that surrounds the control module (use a sturdy knife to get underneath the panel and gradually use leverage to pop it up; do this same process at different points around the panel; BE CAREFUL NOT TO CRACK THE PLASTIC). Once you get the plastic cover (panel) off, you need to unscrew four (phillips) screws that will disconnect the control module from the outer panel. Finally, there is a wire plug that provides power to the unit; to remove, apply pressure to the depressible end (using your thumb) and pull simultaneously. You may have to wiggle the plug a bit but don't pull too hard.
Now reverse the above process to re-install your new control module!
Good luck! :grinyes:
