2001 Texas Rodeo, 4cyl. engine
Google
Web AF
Texas Rodeo
07-15-2007, 04:36 PM
I just got my rodeo back from the dealer. They want to charge me $1400 dollars to do a de-carbonization job. It involves taking out the intake and the head. The mechanic said that with this many miles (120.769) that the carbon got so hard, it required a thorough cleaning and breaking the carbon. So the chemical flush would not help . Is this very expensive for doing this sort of thing, would I be better off taking it to an independent shop. any advice would be greatly appreciated.
thanks.
Cat Fuzz
07-15-2007, 05:05 PM
Sounds like BS to me. Is there some symptom that this treatment is supposed to fix?
Texas Rodeo
07-15-2007, 05:24 PM
Yes. I have a check engine light on. it shows cam sensor, and low EGR flow. If the check engine light is on. I cannot get it inspected. my rodeo also dies during deceleration. The Isuzu mechanic said that is what's causing the engine light to stay on , too much hard carbon build up.
amigo-2k
07-15-2007, 08:19 PM
If you have low egr flow then the egr and the EGR pipe needs to be cleaned (not sure where the egr pipe goes on a 2.2L).
All you need is some carb cleaner to clean the egr and to clean the pipe. Also, some pipe cleaners (like you had when you were a kid, to clean out the egr.
Google
Web AF
