Belt Tensiondsbjdb87 07-11-2007, 07:12 AM I replaced my water pump and also got a new belt. How do you set the tension so you know that it is correct? Is there a special tool? The tensioner roller assembly has a square hole that is probably where a tool goes in to force it out to the correct tension. I tried to use the end of one of my socked extensions, but when I started the van back up, the belt came off. Any help would be appreciated. dewaynep 07-12-2007, 11:51 AM The belt tensioner should be spring loaded and provide the correct tension automatically. If your is no longer spring loaded it is bad and should be replaced. ericn1300 07-12-2007, 09:04 PM He is right, its spring loaded. either frozen or they gave you the wrong belt. dsbjdb87 07-18-2007, 01:34 PM Thanks! I was able to get it on correctly. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
