What part will work?
Google
Web AF
Canuck5056
07-10-2007, 03:16 PM
I need to replace the lock/window switch panel on the driver side of my 94 Camaro. It's this thing:
http://cgi.ebay.com/ebaymotors/97-02-Chevrolet-Camaro-Master-Power-Window-Switch-LKQ_W0QQcmdZViewItemQQcategoryZ50459QQihZ009QQitem Z190130318974QQrdZ1#ebayphotohosting
The driver side window switch has to be pressed down extremely hard in order to make the window go down, and the lock switch is completely loose and doesn't work. Not to mention that when I had the window motor replaced, the garage that did it broke the tabs on the side of the little panel and now it won't stay in the door, it keeps popping out. So I need the whole thing, but I can't find it anywhere except for that ONE on eBay which a) isn't for a 94 and b) they don't ship to Canada.
I've tried all the wreckers where I live and none of them have it.
What I'm wondering is:
1) Is there a specific name for the whole panel? Is the the "Master Power Window Switch" as it's called in the eBay ad?
2) Where can I get one?
3) Will a later model version work, or will it have to be from a '94?
Little help? Thanks!
philly rs
07-10-2007, 05:43 PM
im wanting to say that any lt1 style 4th gen (v6 or 8) will work for that car..when in doubt on what a part is call the dealership they will tell u what u need to know
blindeyed
07-10-2007, 11:49 PM
Why don't you just order that one off of ebay? That's not a bad price. Any from 93-02 should be compatible.
EDIT: Ah, just re-read you post.. they don't ship to Canada, gotcha. That blows.
blindeyed
07-10-2007, 11:57 PM
Here's a few more auctions I found.
http://cgi.ebay.com/ebaymotors/93-02-CAMARO-Z28-SS-MASTER-WINDOW-SWITCH_W0QQitemZ160134953425QQihZ006QQcategoryZ504 59QQrdZ1QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/95-Chevy-Camero-power-window-switch_W0QQitemZ290138060757QQihZ019QQcategoryZ504 59QQrdZ1QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/95-CAMARO-Z28-MASTER-POWER-WINDOW-SWITCH_W0QQitemZ320136660283QQihZ011QQcategoryZ504 59QQrdZ1QQcmdZViewItem#ebayphotohosting
97copcar
07-11-2007, 10:47 AM
I just replaced that exact part on my 97. It is the drivers side switch bezel. I am not sure about were to get it, but hopefully with the right name you might have some luck. Hope this helps. BTW, it is a piece of cake to replace. All you need is a very small flat head screw driver. After you get the panel off, slip the screw driver between the switch and the circuit-board and slowly twist. The board pops right off.
Google
Web AF
