Turn signals not blinking - stay on solid
inflames1969
07-05-2007, 08:33 AM
I have a 1995 Chevy S-10 LS extended cab with the v6 engine. My turn signals do not blink anymore but stay on solid. All the lights work except for one of the license plate lights is out. Does anyone know how I can fix this or what may be wrong? In addition, I also put on the hazards and they stay on solid as well. Basically, the blinking part of the turn signals and hazards does not work anymore. Thanks,
Chris.
wildman_4x4
07-05-2007, 08:38 AM
Usually this is a sign of bad bulbs or a bad turn signal relay I had the same problem thought all was well with the bulbs and found out I had upper and lower bulbs so i replaced all bulbs and been working great for 8 months so far. I might have busted some while installing my hide away Strobes. I am a Vol Fire Fighter. :grinyes:
inflames1969
07-05-2007, 08:47 AM
Hi wildman 4x4,
Thanks for the reply. Where is the turn signal relay located? I don't have an owner's manual so I don't know where to look. Thanks,
Chris.
blazer girl
07-12-2007, 01:20 AM
Actually, I just had my 95 s-10 blazer in the body shop for repairs and had them look at my blinkers because they were doing the same exact thing. They told me that it was my turn signal switch and it would cost $485.00 for them to repair it. I called auto Zone and got a price for $185.00. I will get it and have a friend put it in.It is alot cheaper.:2cents:
muddog321
07-12-2007, 05:59 AM
Should be behind the glove box so grab that left inside corner and bend it so you can pull the glove box out past the stop and let it swing down - theres the cannister.
blazee
07-12-2007, 09:02 AM
Bend the glove box? The stop is spring loaded and just flips out of the way so that the glove box folds down.
