94 jimmy 4x4 not working
seeknstrike
07-04-2007, 11:55 AM
Well my story is.
I have a 2dr 1994 jimmy 4x4, v6 4.3 lit.
She has 115k
When I got the car, The 4X4 was working great. Then I stoped using it, and now the button does not light up at all.
I checked behind the dash, to make sure no wire's where lose. And all the wire's that go to the button are connected.
Is somthing not getting power? What else couldI check?
She has 115k
MT-2500
07-05-2007, 08:52 AM
Check the how to section.
http://www.automotiveforums.com/vbulletin/showthread.php?t=572914
And search some of the other post on here.
Always check power feeds and fuses first thing.
What transfer case do you have?
seeknstrike
07-06-2007, 02:25 AM
I have no clue what transfer case I have. I dont believe thats my problem. How can i find out?
Also, my problem is not getting power. or something to the switch, a fuse ripped power cable. Broken TCU. either way. my switch is not getting power.
Are their fuse's for the 4X4 button / tcu. I followed the wire's from the switch.
some go to the fuse box under the dash.
another on something on the steering wheel,
and a ground.
sorry for my poor English. And thank you for your help.
and a ground.
MT-2500
07-06-2007, 08:40 AM
Your transfer case has a ID tag on the back of it.
Craw under there and have a look.
And while you are under there have a look at the wiring and plug ins under there.
Find fuse boxes and check all fuses for 12 volt power on both sides.
There is a TCCM 5 amp fuse and a 15 amp radio fuse and some ign fuses that power everything.
MT
MT
seeknstrike
07-06-2007, 12:16 PM
Well i was looking for bad vac lines. They all look fine. But, I did find this.
http://i14.tinypic.com/6c3h7v9.jpg
I have yet to check the fuse's. and the Tcu.
I'm removing the batt for an hour then trying it.
MT-2500
07-06-2007, 12:20 PM
Find out whee that piece came from to.
MT
MT
Master.ASE
07-06-2007, 11:00 PM
Check your cable to the front diff and see if it is stuck. this happens when not used mutch. your light wont come on in the dash untill it is actually locked in on the right front axle. seen this alot. Have seen it be the fuse in this case, but Im sure you already checked all fuses
seeknstrike
07-07-2007, 12:30 AM
Still haven't checked all the fuse's.
I'm going to check if its stuck, Could it be switched with my hand if thats the case?
Thank you for your help.
seeknstrike
07-07-2007, 02:13 PM
Found the problem. It was a fuse. The 15 Radio fuse.
Thanks for all the help.
I still need to find out what that broken thing is. Even thought it has not effect driving while its broken. Thank you!
What are some things I can do for my 4wd system? changing any type of oil's?
MT-2500
07-07-2007, 05:06 PM
Your welcome and thanks for posting back how it went.
Glad it was a easy fix.
The transfwer case uses Dexron111 transmission fluid.
Master.ASE
07-21-2007, 11:51 PM
Fuse:smokin: Hey that looks like a vaccume canister. plastick with one vaccume line in. Look for vaccume leak along fender wells and inner panels. they help hold extra vaccume so you dont lose defrost under heavy loads and excelleration.:smokin:
blazes9395
07-22-2007, 10:04 PM
I agree, that looks like what it is. Also you want to replace this, or plug it, as its sucking dirt into your engine.
