1998 Pontiac GTP7futures 07-03-2007, 06:52 AM I am getting a P0341 code causing my 98 gtp to hestitate. Should I change the cam sencor? 7futures:screwy: BNaylor 07-03-2007, 09:29 AM DTC P0341 indicates a circuit/range performance electrical problem with the camshaft position sensor so that may be the cause of the hesitation since it helps control fuel injection system timing. I would replace it or get it replaced. The cam pos. sensor is a DIY job. Easy to replace once the front end engine components that are in the way are removed. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
