looking to get more hp and better pick up with my irocorange_bullet 07-02-2007, 12:18 AM i have a 90 iroc that i put 350 in last year with the b&m ripper shifter. this year i got it supercharged by procharger and installed 3.73 gears in the rear. its been tuned and dynoed at 392 hp. it's fast but i need more. any suggestions. 2.2 Straight six 07-02-2007, 12:20 AM more than 392? smaller puller, intercooler, new internals, nitrous oxide injection.. there are all kinds of things you could do. orange_bullet 07-02-2007, 12:21 AM what do you think i should go with by internals poormillionaire2 07-02-2007, 12:35 AM what do you think i should go with by internals Forged internals. Maybe a stroker kit. More cubes are always good. Dished pistons, lower comp. ratio and more boost. Or you could go with supporting bolt-ons if you don't already have those. Longtube headers, true-duals, cutouts, suspension and chassis, heads and a blower cam. Morley 07-02-2007, 02:17 AM More displacement, twin turbos & intercoolers philly rs 07-02-2007, 05:14 PM yeah u need forged internals and alot more boost!!!! and the bolt ons that were mentioned if u dont already have them orange_bullet 07-03-2007, 02:32 PM i was told that if i got more boost that i would have to change my injectors and that it may cause problems down the road. would there be more to change and would it cause problems later philly rs 07-03-2007, 02:59 PM wth??? why would it cause problems? im about to throw sum 42 pound injsectors (if i remember correctly) in my car...new set up will be 2 stage n2o...75 dry shot off the line, followed by a 150 wet shot at a pre set rpm working off a window switch... right now im doing a 100 shot and the injectors cant keep up, so im gonna have to go big..so will u if u up the boost..only thing that will mess up is your wallet when it comes to gas lmao! as long as u tune the car correctly after u have done an aplication like that and balance everything correctly for your setup then u will be just fine man! hotrod_chevyz 07-03-2007, 04:22 PM Get a 454. If you want bigger numbers get a bigger motor. If its a street car than the HP you have is plenty for a car as light as yours. And how the hell does it only have 392 HP with a S/C? You can get a 350cid to push 375 HP with all stock parts... orange_bullet 07-04-2007, 01:52 AM i was looking into getting a new intake, runners and base then maybe new heads for the bolt ons. how much more power do you think i would get vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
