Failure Codes on '97 Jetta
Google
Web AF
bobsthebomb
07-01-2007, 09:13 PM
My 1997 Jetta GL, 2.0 5-Speed car failed inspection on code 1582 and the Volkswagen dealer said that it had a bad throttle body. Throttle body was replaced with a used one and we still cannot get that code cleared. When you clear the code, it stays out for a day to two days and then the engine light comes back on with the same code. If anybodys got an idea of what is going on, please give me some sort of information????:banghead: :runaround:
bahnfire
07-22-2007, 12:36 AM
Cleaning the internals of the throttle body may work. Visit this thread for more info:
http://forums.vwvortex.com/zerothread?id=1319844
veedubmechanic
07-28-2007, 06:06 PM
Make sure the connector is plugged in all the way. VW used a stupid style connector thats hard to connect and disconnect. The wires may be broken also because of the bend right next to the connector.
1582 is also idle speed adapt limit reached
I would reccomend cleaning the mass air flow sensor off and cleaning the throttle body and inside of intake manifold with throttle cleaner available at most all auto parts stores.
bobsthebomb
07-29-2007, 08:55 AM
Thanks guys,but now i have other codes that came up.They are 501 and 411.Any input you have on this is greatly appreciated.bob
2001jettavr6
08-12-2007, 02:44 AM
1582 is malfuntion in vehicle speed control, its more than likely your catalytic converter is bad, which is the main reason for your failing inspection.
bobsthebomb
08-28-2007, 07:18 PM
Thanks for the input!I have checked everything and think it might just be the converter.Can i drill a hole thru it just to see if it is the converter?Any way to tell before i spend alot of money on a converter?Thanks:runaround:
Google
Web AF
