Fuse Problem when A/C is turned onTheDeal526 06-24-2007, 07:49 AM 1997 Pontiac Grand Am SE 3.1L 100,800 Miles For some reason sometimes when I turn the A/C on one of the mini fuses under the hood will go bad resulting the the A/C compressor stopping, and the brake light will come on. The shifter can not be moved from park, I assume this has something to do with the brake light. Does anyone have any idea whats causing thisi fues to blow when I turn on the A/C? Thanks!!! skibum1111 06-24-2007, 11:46 AM Check the wiring going to the compressor clutch. Might possibly be rubbing on the engine or another metal part, causing a short. Correct guess on the shifting issue. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
