ac/blower/vent question 95 blazer95blz4wd 06-23-2007, 09:16 AM The air from my airconditioner will not completely come thru the vents. It blows from the defrost and heat not out of the vents. It seems that about 50-55 mph it will blow completely from my defrost etc. however if I let off the gas or go down hill thus relieving strain on the motor it will partially blow out of the vents again. I am completely confused and don't even know where to begin? Please help, Sam MT-2500 06-23-2007, 10:46 AM Vacuum. Start at engine where the vacuum line hooks up to it. And trace it to ac/heater controls. Check vacuum tank and check valve to. At the check valve is a good place to test for full vacuum. MT 95blz4wd 06-24-2007, 12:19 PM I will attempt to follow the lines today and see what I can come up with! Thanks again for your response! Sam mysonomaneedshelp 07-03-2007, 09:29 AM I have the same problem with my 96 Sonoma and the blower. We have followed the lines and have even taken the dash apart. The lines we need access to appear to be behind the radio and are the only ones we can't get to. The dealer said I probably have fluid in my lines and it could be eating away at them. Are there any good diagrams of the HVAC lines out there? Any suggestions? The dealer wants over $1200 to fix it since it is so labor intensive (or so they say). MT-2500 07-03-2007, 10:23 AM I have the same problem with my 96 Sonoma and the blower. We have followed the lines and have even taken the dash apart. The lines we need access to appear to be behind the radio and are the only ones we can't get to. The dealer said I probably have fluid in my lines and it could be eating away at them. Are there any good diagrams of the HVAC lines out there? Any suggestions? The dealer wants over $1200 to fix it since it is so labor intensive (or so they say). Welcome to AF A different vechicial needs a new thread/post started on it to better help you. Two vechicels on one thread gets confusing. Please start a new thread.. http://www.automotiveforums.com/vbulletin/newthread.php?do=newthread&f=2072 http://www.automotiveforums.com/vbulletin/showthread.php?p=4820845#post4820845 jbarsalou 07-10-2007, 05:39 PM How much vacuum is expected? MT-2500 07-10-2007, 05:53 PM How much vacuum is expected? As much as the engine vacuum is. Around 18-20 in. hg is good. MT vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
