Couple Codes in the System
Google
Web AF
rkuchar1
06-21-2007, 10:05 PM
I was wondering what the following codes are.
I had my service light come on the mechanic said that I have the following codes stored in the computer.
I had one come on; he says I have an EVAP leak. But also said that there are a couple codes for
P1602 SAys it is for the ABS
P1641 Says it is Improper Voltage Output Circuit A/C COntrol
xeroinfinity
06-21-2007, 10:35 PM
p1602 - serial data communication failure with electronic brake control module
I would say the EBCM has troubles or has at one time.
p1641 - Malfunction indicator light control circuit
Do you have a bulb out ?
rkuchar1
06-21-2007, 11:08 PM
highbeam light is out on Passenger Side
EBCM what's that?
xeroinfinity
06-21-2007, 11:21 PM
:uhoh: EBCM = electronic brake control module
depending on your year the module is in different locals.....
rkuchar1
06-22-2007, 12:58 PM
thanks for your help...ONce I posted it, I thought it probably was an acronym for brake control.
I searched the forums; for this. I seen a response that you gave on some else's problem. COuld I tell which sensor is going without having it scanned?
xeroinfinity
06-22-2007, 01:27 PM
Probly not.
It could be a short or malfunction, if it got wet or thier's a short in the wiring.
The ECBM is only 1 module, it controls the ABS and SRS signals to process. Usually under the pass seat.
The stealership or someone with a Tech II (or compatible) scanner can tell what's wrong.
Google
Web AF
