Cooling fans runningParatrooper509 06-21-2007, 08:40 PM I've got and 88 IROC w/ 350. The cooling fans run all the time (when the key is on). Could it be a sensor? If so, any suggestions. It was suggested to me that it may be in limp mode (computer problem). The car runs like a beast though. Morley 06-22-2007, 02:51 AM Is the check engine light on? Does it even work? If those are ok, look for a previous owner to have hard wired them to run all of the time or maybe put them on a switch that has been left on. Now, if you've had this car for a while and this has just started happening...then I'm back to limp home mode. wrightz28 06-22-2007, 10:05 AM Is the check engine light on? Does it even work? If those are ok, look for a previous owner to have hard wired them to run all of the time or maybe put them on a switch that has been left on. Now, if you've had this car for a while and this has just started happening...then I'm back to limp home mode. :1: But, if it just started happening, and the the CEL is not on and passes the bulb check, then I'd be looking at the fan switch and it's wiring. Morley 06-22-2007, 02:50 PM :1: I'd be looking at the fan switch and it's wiring. I do believe in 88 the fan was still triggered by the ECM, not a switch (could be wrong on this one) Another thing to look for is the fan realy contacts welded together. wrightz28 06-22-2007, 03:10 PM Yeah, remember my woes I had in summer '05 with my fan, that was on my '85 which some to find 86 & up used the switch on the passanger side. I'm pretty sure my T/A also a '88 has it. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
