torque specification for hub nut 99 blazer 4x4
Google
Web AF
vando002
06-20-2007, 02:31 AM
I'm finishing up replacing the bearings on the passenger side and there was no torque specification for the hub nut in my haynes book, only the bearing assembly bolts. I'd like to get it all together asap and was wondering the specs on the hub nut if anyone can help. Thanks.
laxman21
06-20-2007, 09:04 AM
http://vsmus-origin.skf.com/Files/Brochures_in_PDF/457377.pdf
says...140
vando002
06-20-2007, 11:46 AM
In that pdf on pg6 it says 103/140 with the heading saying "Front Proc or Torque Ft-lbs/Nm" so it's 103 Ft-lbs/140 Newton meters, right?
blazee
06-20-2007, 02:16 PM
Yes, that's correct 103 Ft/lbs.
vando002
06-20-2007, 03:53 PM
Thank you much for the help. Now I can finish up the passenger side and do the driver side!
Google
Web AF
