Daylight lights not working!!!
Google
Web AF
jeffer19702
06-19-2007, 04:46 PM
My regular headlights are on all of the time. This problem has only just started. How do I get my daylight headlights back on? I have a 1999 Chevy Silverado
silveradoman0574
06-19-2007, 05:51 PM
Check the sensor on your dash in the middle. If something is over it then it will be dark for the sensor and make the automatic headlights come on.
silveradofirerescu
06-20-2007, 11:59 AM
You could always try overriding the automatic headlights by pushing the dome override button 4-5 times until you hear a chime. I don't know if this will cause the system to revert back to the DRLs though. Other than that, I agree that you have a problem with the sensor in your dash. Hope this helps.
chuck16
06-21-2007, 12:00 PM
Dome Switch trick doesn't work on a 99'. Something wrong with your daylight switch. Pull your stereo out and look behind and see if your ambient light switch has become disconnected.
I wired a switch in parallel with mine so that you can have automatic or manual control over your headlights. Just need to put a 1.5 K ohm Resistor in parallel with the light sensor through a switch....
http://files.automotiveforums.com/gallery/watermark.php?file=500/217712aheadwiring.jpg
swizzz818
06-26-2007, 08:26 PM
where is the dome override button ? will this work on a 2005 silverado ? i have double limo tint on my truck all the wayt around and because it is so dark in the truck with the windows up my DRL's are constantly switching from off to on in the day time. It gets kind of annoying the only thing i can do is just manually turn off my headlights when i notice this.
rjeffery
06-26-2007, 10:52 PM
Dome override button is next to the headlight switch. It is a push button. The sensor is at the back of the dash near the windshield, so I wouldn't think that the tint would effect it that much.
swizzz818
07-13-2007, 08:10 PM
man i was looking and my lil dome in the middle of the dash for the lights got pushed completely down like its not even visible thats why my lights DRL arent on all the time does anybody know how i can pull it back up ? i guess i pushed it down by accident while wiping down the dash
rjeffery
07-13-2007, 10:20 PM
Take the bezel off, and try to get at it that way.
hcetri
07-23-2007, 11:41 AM
Will removing the DRL fuse work because I am having the same problem
silverado122775
07-24-2007, 10:56 AM
YOu could do that. It won't hurt anything, unless the DRL fuse is attached to another electric compenant.
Google
Web AF
