Need help with back Window (96 Blazer)
Google
Web AF
Steveschr
06-18-2007, 07:48 PM
Dear Blazer Owners,
For some reason my rear window release on my 96 blazer is not working. I have tried the manual override but still cannot get the lock to realease so that i can open the window. Any suggestions, i'm lost at this point? Thanks.
1996 Blazer LT
4.3 Liter V6
165K Miles
MT-2500
06-19-2007, 10:04 AM
Fuse and power supply to it?
If all else fails you may need a good service manual to help you thew it.
arossr0914
07-02-2007, 11:48 AM
i have the exact same blazer and i had the exact same problem, check if when you open the door, does the dome light go on? also does the top cigerette lighter work? if both of these do not work then it is absolutely a fuse problem. fuses are located on the left face of the dash they almost rest against the driver door when it is closed. if not, it is something mroe serious and should be looked into with further detail.
BrEnDaNb
07-03-2007, 12:47 AM
solved this exact problem couple of weeks ago. if you have tried manual release and nothing happens take a flashlight and look inside the opening there is a metal latch that has disconnected,and more than likely fell forward so you cant identify at first glance. you will need two screw drivers, one to rotate latch counter-clockwise up and the other to secure its position. just keep messing around with it and eventually you will understand how it works. Good luck
Google
Web AF
