Engine Seizes with starter installed
jwalker1970
06-18-2007, 10:41 AM
I have a 98 Contour in the shop with a 2.0L 4cyl. It ground over very hard and locked up the engine with the original starter (assumed defective).
#1 Replaced starter with new starter.
#2 Same problem. Car rolls over hard, don't start & locks up engine....can't be turned over with breaker-bar on crank.
#3. Removed starter, car turns over freely with breaker bar.
#4. Installed 2nd new starter, same problem.
#5. Removed spark plugs with starter in place, still locked up.
#6. Loosened torque converter bolts, verified flex-plate wasn't loose.
#7. turned engine over without starter in place & inspected gap between flex plate & a stationary position on the bell housing. Uniform gaps while turning over.
#8. Verified that vecicle came with and called for a 10 tooth starter.
Still same problem.
Any ideas??
pre98zetec
06-18-2007, 10:45 AM
are the accessories spinning freely? locked waterpump/ac pump could cause this too.
jwalker1970
06-19-2007, 03:41 PM
accessory belt is off.
beyondloadedSE
06-19-2007, 08:33 PM
So whats the flywheel look like?
