Grand Cherokee 01 Fan Running with Key OFFerick0071 06-18-2007, 01:12 AM My Jeep Grand Cherokee Laredo 2001 4.0lt. motor. started having some problems two days ago. The fan stopped kicking in and I tougth it was the fan relay again since i have replaced before. But i got another one and the fan still wont kick in ...the funny thing is that it will run with the key off ..whenever I turn the car off the fan will kick in and stay on. I tried to find a short somewhere but cant seem to find anything. I would like to know what else could be causing this aside from the relay since i have 4 diferents and they all do the same thing so i am pretty sure is not the relay this time. Could anyone point me in the right direction. Could a bad Powertrain Module be a problem. or should i look somewhere else. Bob D. 06-18-2007, 07:43 AM Well, the PCM tells the relay when to turn the fan on but my guess is the relay is wired wrong, shorted etc. Test the continuity of the fan/relay circuit. Note: If you have replaced three relays on a 2001 I would check the currant draw of the fan. erick0071 06-19-2007, 11:04 PM Well.. cant seem to find a short but will look harder. Is there any place in particular to look closer? I also checked current draw of the fan as the last post recommended and it was around .50 amp ...is that ok? I will be willing to try anything you would suggest and any tips on how to find a short in such a tangled wiring. Bob D. 06-20-2007, 01:07 AM Well.. cant seem to find a short but will look harder. Is there any place in particular to look closer? I also checked current draw of the fan as the last post recommended and it was around .50 amp ...is that ok? I will be willing to try anything you would suggest and any tips on how to find a short in such a tangled wiring. Then the fan relay has failed and you will need to replace it. hulkmn069 06-20-2007, 10:32 PM i agree when my relay went bad that's what it did was run the fan with everything off till it killed the battery. i had to pull the plug until i replaced the relay Automotive Network, Inc., Copyright ©2012
