Our Community is 662,000 Strong. Join Us.
03' GCL, tranny leak
jonzi216
06-17-2007, 12:24 PM
For a week now I noticed a tranny leak(few drops) under the front end of the jeep..after laying under the jeep I see a hose with a metal cupling at one end, seems like an easy fix (replace), does anyone have fotos or istructions on how to replace this hose???
JeepForever
06-25-2007, 10:48 AM
Is it a rubber hose or a metal (screw-on) tube? There are tubes going to the radiator to cool the trans fluid. These can be tightened. If it's a rubber hose you might want to try a new ring-clamp. Or you can measure the length of hose and go to a place like AutoZone and get a new piece of hose (although I'm not familiar with the type of hose you're referring to - they might know in the store). If you can see both ends of the hose you'll know how much you need and what it takes to replace it.
On a '93 if you only have a few drops you might try some trans fluid "leak-stop". That worked for my '04 and brought it down from a small puddle to a few drops after about 300 miles.
hulkmn069
06-25-2007, 06:11 PM
On a '93 if you only have a few drops you might try some trans fluid "leak-stop". That worked for my '04 and brought it down from a small puddle to a few drops after about 300 miles.[/QUOTE]
leak stop is bad ju ju in our transmissions there's a nylon check valve in the cooler lines and putting leak stop swells the valve and cooks the trans. you'll be slipping into the second gear shift like me.
