where is the gas filter 2004 z71bennyleroy 06-16-2007, 09:09 PM I have had more Chevy trucks then I can count, and changed every gas filter BUT I can not find the filter for my 2004 sliverado z71 5.3 . Is it possible Chevy did not put filters on that year??? BlenderWizard 06-16-2007, 10:47 PM did you check inside the frame rail near the back of the cab on the driver's side? mcconnell45 06-17-2007, 11:45 AM I'm pretty sure on 2004 and up Silverados, GM put in lifetime fuel filters into the fuel sender unit inside the tank, pretty much making it a non-servicable part. Also in some of the '04 Manuals it will say the truck is equipped with a replacable fuel filter, this however is a misprint. BlenderWizard 06-17-2007, 06:53 PM I'm pretty sure on 2004 and up Silverados, GM put in lifetime fuel filters into the fuel sender unit inside the tank, pretty much making it a non-servicable part. Also in some of the '04 Manuals it will say the truck is equipped with a replacable fuel filter, this however is a misprint. Mine (2002) has 2; one in the tank, and one in-line in the location previously described. bigbadram51 06-17-2007, 08:22 PM In my 04 I have only one, and its in the fuel tank. FiTxAg04 06-18-2007, 12:23 AM It's non-serviceable in the fuel tank. wrparks 06-19-2007, 06:18 PM That's funny, I was crawiling aroudn under mine a while back, and it definitely has one along the frame on the drivers side, maybe 2 feet away from the tank. But, mine is the 4.3, so that may make a difference. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
