Removing the transmission on windstar 1995 3.8Lmramstedt 06-16-2007, 06:58 PM Hi! After having the tranny fail and hammer like a sledgehammer, I got today to where I was going to pull it out. I got to where I have all the mechanicals out from the tranny and was trying to remove the nuts from the starter opening. I got the first on out, cranked the engine, got the second one out, then the engine won't move at all. I'm afraid to snap the crankshaft bolt if I put more force on it. What is wrong??? Can the tranny be locked up so the flywheel won't turn? Please help! 12Ounce 06-16-2007, 11:42 PM Is the tranny housing still bolted to the engine? And are all mounts still in place? How are you cranking the engine? I usually use a large screwdriver in the flexplate toothed ring. You may end up having to take the back cover off of the tranny and pull the valve cover and pump shaft as a start to see if things will loosen up. If not ... drop the engine and tranny along with the sub-frame ... that's the way Ford installed it, all together. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
