Reverse Indiglo Gauges
Google
Web AF
Revolutionary15
10-27-2002, 12:21 PM
I am getting ready to put reverse indiglo gauges on my truck. I am looking for any helpful hints before I start. Anything helpful will be appreciated.
Silverado1500
10-27-2002, 08:57 PM
You may want to check into getting it professionally installed.
The reason I said that is it took us 1 1/2 hours to install and the speedomoter needle gets stuck sometimes. It gets stuck at about 35 mph every once and a while, but when you go about 40 it fixes itself. Usually passed 40 it doesn't stick. It's not too bad, but sometimes it can be annoying. We may have to take it in eventually and see what's up.
I've got 5 color white faced gauges. Around 10 shades for each color too. They're really nice and not many people have them.
BluJ
12-25-2002, 06:19 PM
WATS UP GUYS, I WANT TO BUY THE AC AUTOTECHNIC REVERSE GAUGES, AND I HEARD A LOT OF THINGS ABOUT REPLACING THOSE GAUGES. THE NEEDLE IS SENSITIVE AND YOU MIGHT MESS UP THE WHOLE CALIBRATOR, AND THE THING I AM SOOOOOOOO WORRIED THE MOST IS THAT IF MY NEEDLE MESSES UP, MY WHOLE WARRANTY IS VOIDED. WHERE IN NEW YORK CITY IS A SUPER PROFESSIONAL WHO CAN PUT THE GAUGES AND THE NEW NEEDLES I JUST SAW, SAFE AND SOUND? PLEASE GUYS HELP ME OUT ON THIS ONE. THANKS A LOT
airpanefixr
01-18-2005, 12:17 AM
I put the reverse indiglo gauges on my silverado and love them. Before you do anything test out the lights by touching them into the cigarette lighter. I bought the AC lights and they shorted out 2 times before I got a good one. I initially had the same problem with the speedometer and tach. To fix the problem I took the 4 little pins out for the top and bottom of the speedo and tach and used a drill bit to oversize the holes a hair...just a hair though. Also when you put your needles back on, don't push them down as far as they go. As for a electrical source, connect into the purple wire on the dimmer switch on the lighting control panel and then find a good ground.
firedogmatt
06-18-2005, 06:26 PM
I just got a 2000 silverado. Can someone tell me what the hell is the two half circles in the bottom left of the gauge? I can get a picture if someone want's me to?
JCL82
06-18-2005, 06:47 PM
I was wondering the samething.I think it's just there for looks,because in some trucks it has a trans. temp thing there.Maybe someone can give us a answer.
airtight_python
06-18-2005, 07:12 PM
The "two half circles" is just a filler for a place where the trans temp is on the upper model trucks. If you want the trans temp just stick in a Denali or Escalade cluster.
spudglo08
06-18-2005, 09:24 PM
The 2500 (HD) and 3500 series trucks have trans temp guages their cus they have HD trannies
jeep_cj4x4
06-18-2005, 09:52 PM
What, and my 1500 non-HD truck is supposed to sit in the driveway and look pretty...
Stupid GM.
jethro_3
06-18-2005, 10:02 PM
I have the towing package, the heavier suspension, and the trans cooler. And for some funny reason you have no reason to worry about the temp unless you get a heavy duty....
BlenderWizard
06-18-2005, 10:21 PM
Do you know what option code this towing package is in the glovebox? I was told this truck had it by the sales guy when I got it, but I just want to double check it. I have all of the towing hookups (factory), factory lsd. I've never looked for the tranny cooler, but how much beefier is the suspension?
nineball481
06-19-2005, 03:30 AM
If you have the tow/haul button on your shifter lever, you have the tow package. I can't remember the code or where I put my print out of them, but if you search this forum for "RPO", you should come up with a thread that has a link for the codes. Or you could do a google search for "silverado RPO codes".
jethro_3
06-19-2005, 08:28 AM
THESE ARE THE OPTIONS THAT PERTAIN TO THE TOWING EXTRAS:
Z82 - Trailering Special Equipement
VR4 - Weight Distribution Platform Hitch
UY7 - HD 7-Lead Trailer WIring Harness
Q4B - 6,200 LB GVW Rating
M30 - 4-SPD Automatic Trans with Tow Haul Mode
KNP - HD Aux Trans Cooling System
And the most Important Towing Option
#OS - Onstar System for when your ass is in trouble...
airtight_python
06-19-2005, 12:34 PM
I have the tow/haul button but do not have the tow package. I've got a base model V6 sportside, barely has anything.
BlenderWizard
06-19-2005, 01:09 PM
Well, I guess that's one thing the sales guy wasn't lying about. Is the positraction rear end (G80) standard for the towing package?
jethro_3
06-19-2005, 05:29 PM
G80 was not always put together with the towing package, I really wish I had it.....
firedogmatt
06-20-2005, 06:08 PM
suppose I do put a escalade cluster in there, Do I have to rewire it or does it just plug in like my does? does everything line up right, as far a bolt pattern?
Picture of it anyone???
jethro_3
06-20-2005, 06:50 PM
Check out this thread nad you will get all you wanted to know nd more....
http://www.automotiveforums.com/vbulletin/showthread.php?t=412273
nineball481
06-20-2005, 09:31 PM
here is a pic of my escalade cluster in my 00 silvy:
http://home.indy.rr.com/imac/truck8.jpg
Everything is a perfect fit, looks completely factory ...in a way it is completely factory... Easy swap. all conectors match and everything works when changed over. Even going from 100 speedo to the 120 speedo, makes no difference. Enjoy.
Jake
jethro_3
06-20-2005, 09:37 PM
Nineball, I bought the same as yours. I agree that white is to flashy and the Platinum outline adds just the right amount of class. Got the 120 speedo after the Nelson Tune and now it tops out at 130. I had to test the speedo but only got to 120 before I ran out of road on the way to my coworkers house. On the way back the cops would not let me open up like the truck wants to. Tempting, very tempting.....
clean95
10-25-2005, 02:05 AM
I just installed the REVERSE GAUGES in my 1995 Z 71 4x4 they was given to me. the wires to connect are red + black - . My question is can I hook the red wire to my dimmer switch ? My gauges only have a off on buttion. I have it to my head lights right now but they are very bright at night .
Google
Web AF
