88 corsica stalls only when first started up
Google
Web AF
natashagwitt
06-07-2007, 09:14 AM
Hey-
I've had this car for about 3 weeks.
The past 3-4 days, when I get up in the morning to leave, I'll start the car up, which is just fine - then I either reverse or drive, depending how i am parked and the car stalls. Then I put it in park, turn it off, and start it back up again - and I can drive/reverse just fine.
I think it may just happen when the car sits for a long period of time, but I am not sure. Sometimes, I go out in the afternoon after it sits for a few hours, and it doesn't have the problem..
ideas??
jsgold
06-07-2007, 09:01 PM
hard to say here, but you might have a dirty IAC valve that is affecting your idle speed maybe. Might check for old cracked vacuum lines, clean your IAC, tune it up if not done for a long time, and see what happens. If you notice your check engine light coming on ever, get the codes pulled in case you have a failing sensor etc.
natashagwitt
06-08-2007, 07:47 PM
Well, it was bad gas.
Put some heet in, and walla-- no problems.
Google
Web AF
