timing belt replacement Holden shuttle isuzu
woolroad
06-07-2007, 05:50 AM
Hi ,
Could someone if they have changed the timing belt on a holden shuttle isuzu 2.0 l motor explain where the top dead centre is , the reason why I ask is the belt has broken now I would say the pistons might have hit the valves but I need to try the cheaper option. The orginal belt was replaced 77,000 km ago only to find the belts gone again.
When I look at the top pulley it has a mark on it which lines up with housing , but what the bottom end.
Thanks
Peter
atfdmike
06-07-2007, 06:49 AM
What year is your Isuzu and do you know any other names it went by. I am in US and don't recognise model name "shuttle". Also, are you sure of displacement being 2.0 L? I took a look and did not see that size motor, but I did not spend much time looking since I did not know the year.
woolroad
06-07-2007, 08:53 AM
Hi ,
Thanks
Peter
The model is 1985 Isuzu , re-named as Holden Shuttle 2.4 L .
Thanks
Peter
atfdmike
06-07-2007, 10:12 AM
Hope this helps, it is for 85 Isuzu 2245cc 2.3 L SOHC. It was all I could find that was close. Top dead center for #1 would be when timing mark on balancer is at 0 mark on degree indicator . good luck.
Fig. 19 Aligning crankshaft timing pulley & front oil seal retainerhttp://library.alldatapro.com/alldata/LIB~C5095~R0~OB0~P3R0H~N/0/41745988/56620415/56620420/56620423/34853741/100411974/34853743/88986183/88450514/108894052/41954277
Fig. 20 Aligning camshaft timing pulley & front platehttp://library.alldatapro.com/alldata/LIB~C5095~R0~OB0~P3R0H~N/0/41745988/56620415/56620420/56620423/34853741/100411974/34853743/88986183/88450514/108894052/41954278
