99 Silverado key cylinder will not return?
Google
Web AF
lawverco
06-04-2007, 07:31 PM
Newbie here! My key cylinder will not spring back to the run position once it is started. it works fine if i just pull it back. Will this be a problem with the Key? Cylinder? or the housing around it? Can it be replaced fairly easily with out the airbag being disabled?
Thanks
Tdragone
06-04-2007, 11:21 PM
Go to a locksmith and get some dry graphite powder to lubricate the cylinder. I don't think GM uses a wet lube in the ignition.
The Locksmith can tell you for sure...
Google
Web AF
