FPR and Fuel Filter
Google
Web AF
silveradofirerescu
06-02-2007, 06:12 PM
I have a 2002 Z-71 with the 5.3. The truck has always started hard and after some searching I have learned this is caused by a faulty FPR some times. Now I am new to Chevy and do not know where my FPR is or ever what it looks like. Can anyone help me here? From what I;ve read it seems like a common problem. Also, I believe it is time to change my fuel filter while I am at it. Where would that be located as well. Any pictures would help greatly.
Derek
BlenderWizard
06-02-2007, 06:26 PM
As far as the FPR, I dunno, but the filter is in the frame rail near the back of the cab on the driver's side. It is about a 5 - 10 minute operation to change the filter, too. I would start with it and see if it helps.
silveradofirerescu
06-02-2007, 06:50 PM
Awesome, thanks. I am just hoping like hell that it is not a fuel pump issue as I have neither the time nor ambition to look into that. Thanks again.
MT-2500
06-02-2007, 08:20 PM
Derek
Left side of engine on fuel injector rail.
A quick test is to pull the vacuum off and look for fuel in it.
Also a good time to check fuel pressure.
MT
silveradofirerescu
06-02-2007, 09:18 PM
OK I located the filter, any sugestions as to which brand to replace it with?
Blue Bowtie
06-02-2007, 11:47 PM
Delco/Champion Labs, Wix, or Hastings are all good quality filters. Fram and all their house-branded clones are highly suspect. I believe NAPA is supplied by Wix for most of its filters, but I'm not positive of that.
BlenderWizard
06-03-2007, 07:37 AM
I've always used Purolator
vnotaro
06-03-2007, 12:09 PM
[QUOTE=silveradofirerescu]I have a 2002 Z-71 with the 5.3. The truck has always started hard and after some searching I have learned this is caused by a faulty FPR some times. Now I am new to Chevy and do not know where my FPR is or ever what it looks like. Can anyone help me here? From what I;ve read it seems like a common problem. Also, I believe it is time to change my fuel filter while I am at it. Where would that be located as well. Any pictures would help greatly.
Have you ever changed the filter? If not, the lines could be tough to get off. Get yourself a set of flarenut wrenches for the job. They'll grip better and there is less of a chance of stripping or deforming the nuts on the ends of the fuel lines.
gremlin96
06-03-2007, 12:51 PM
if your truck has the same filter problem as mine be ready for some cussing. the lines were bent at the factroy. after i gently put the bend strate the filter lined up with the line and threaded right in. next filter change will be a snap.
wafrederick
06-03-2007, 07:16 PM
You might want to check the fuel pressure first before anything.GMs will not run under the specified fuel pressure.Stay away from aftermarket fuel pumps,they are junk and will not cover under warranty 99.9% of the time.Go with one from the dealer.
Google
Web AF
