Blower-Supercharge-Turbo
Google
Web AF
bcsintegra
10-25-2002, 10:31 PM
Would a Super or Turbo charger, or blower mess my heads, or my motor up if the motor is 10:1 or 11:1 comp. piston?
kidrocket
10-26-2002, 01:35 AM
we do have an acura forum:confused:
BlkCamaroSS
10-26-2002, 02:19 AM
He's asking about for his 82 Camaro cool guy, way to pay attention...
kidrocket
10-26-2002, 10:57 AM
well lets see. this was the only thread i read, his name is bcsintegra, and he says he has a 99 gsr in his info, so stfu
BlkCamaroSS
10-26-2002, 11:03 AM
Excuses, excuses...
kidrocket
10-26-2002, 04:56 PM
joo motherbish :finger4:
Jay!
10-26-2002, 05:00 PM
WTF? :confused:
BlkCamaroSS
10-26-2002, 05:45 PM
PMan??? What's up with that???:confused:
gemballa
10-26-2002, 06:38 PM
i think a turbo!
Black_97'Z
10-28-2002, 12:34 AM
Any compression above 9.5 is not a good idea for a supercharger or turbo setup. You can crack pistions, blow head gaskets, etc.......
bcsintegra
10-28-2002, 05:29 PM
Yall SOB's are crazzy. I do have a 99 Integra GSR. I am asking these questions about the Camaro for a friend. So you think a blower would be the best choice so I don't fuck up nothing?
bcsintegra
10-28-2002, 05:32 PM
I am helping him drop in the 350!!
:finger4:
Black_97'Z
10-28-2002, 07:05 PM
A centrifugal type supercharger would be easier, and a better choise than a roots-style supercharger.
gemballa
10-30-2002, 03:59 PM
most of american cars are modifieds with chargers because there are easier to install than a turbbo
Black_97'Z
10-30-2002, 04:39 PM
So your saying it's easier to design and install a turbo setup on a non-turbo Import, than a domestic.............
BlkCamaroSS
10-30-2002, 09:43 PM
I'd take an Icon TT setup for my SS in a heartbeat, too bad they aren't being manufactured anymore...
Black_97'Z
10-31-2002, 01:58 AM
Like this one..... :smoker2:
http://stropespeedshop.com/incon_install_front_throttle_body_w_inlet_tube.jpg
-cy-
11-09-2002, 06:54 PM
11:1 comp ratio, no, 10:1 maybe. You could use thicker head gasgets, and if you have cash get the combustion chamnbers on the heads milled for lower CR.
Turbo kits for LS1's haven't really been perfected yet, at least i don't believe they have. The supercharger kits are a more popular choice. I think most of the kits are 6psi kits, which should be find with a stock bottom end, some are 9psi kits, which i guess is ok, but if you want your engine to last longer i'd stick to 6psi with stock internals.
Black_97'Z
11-09-2002, 07:05 PM
Thicker head gaskets wont lower you CR enough to make a difference. The only way to do it is to get dished pistons or different heads with a larger combustion chamber.
-The Stig-
11-14-2002, 02:44 AM
Superchargers and 'Blowers' are the samething.
Just thought i'd point it out... figured somebody had too:confused:
Self
11-15-2002, 09:11 PM
If your fuel system is up to par you can run 9 - 11 lbs perfectly fine with no problems. Stock pistons are actually HARDER than aftermarket performance pistons. That's their downfall actually. They're so hard that they are also BRITTLE. Which means if there is ANY detonation at all you will have PROBLEMS. But as long as you have absolutely NO detonation once so ever you'll be good to go! This is why there are people running 250 shots of nitrous on stock internals. All you really have to worry about is your crank. BUT for what you'll pay for a fuel/management system capable of doing the above safely, you could buy a supercharger/heads/cam/forged internals. The only reason I know of people doing this is to say they run a 250 shot on nitrous, lol. But anyways, just wanted to point out it IS possible...
And also, a blower and supercharger is the same thing, but generally when you say blower you're referring to a roots charger, and supercharger is used to refer to a centrifugal charger. Not my lingo, but THE lingo none-the-less...
-cy-
11-15-2002, 09:16 PM
Of course you can go 9-12psi if your fuel system can handle it, but why not just lower your compression a bit as well as a forged crank and all. Also, i dunno about you, but i don't wanna have to worry about that 1 time you detonate and your engine is done for.
Self
11-16-2002, 04:15 AM
Oh yes, I agree with you wholeheartedly. Just thought I'd point out that it can be done. POINTLESS in my mind...EXCEPT if you just want to be able to brag that you run 12 lbs on stock internals, or a 250 shot on stock internals.
brutisrazutis
09-16-2007, 10:14 AM
well im pretty sure you would be ok with a blower/supercharger or turbo.... i have a 76' maro with a 350. i have a 142 cid. weiand blower/supercharger. im running 5.45 lbs. of boost. i DONT have forged internals and its perfectly fine. i used the stock heads. but later upgraded to a set of aluminum heads. as long as you can run pump gas in your car now without any knocking or pinging then you should be good... i usually run 91 octane (gay ass california) with lucas octane booster. its totally fine. but u might want to up grade your distributor to a mechanical advance with an adjustible timing curve (MSD pro billit distributor) and you might want to get stage 2 cold spark plugs (to prevent pre detonation). if you have any questions regarding an installation on a blower then let me know and ill be more than happy to help you out and talk you through it. i pretty much ran into every problem you can with installing one. so i know how to fix almost everything.
Blackcrow64
09-16-2007, 10:34 AM
Wow... How about next time you read the last posted date before replying to a thread. This thread is almost 5 years old... :shakehead We don't need to be bringing back threads from the dead...
Locked...
Google
Web AF
