Easiest Waywykydjuggalo 05-26-2007, 02:47 AM What is the easiest way to install a push button start on my 73, i'm having trouble with the ignition and just want to turn the key to te on position and push a button to start it. It as a straight 6 in it, somtimes it starts on the first try others i have to turn the key back and forth untill it starts 74NovaNick 05-31-2007, 06:01 PM I don't know much about electronic starters....but I DO know quite a few on ignitions itself. I had a break in last month and the SoB tore up my cloumn and jammed my IGNITION LOCK CYLINDER. This is prolly the piece you want to replace rather than an electric hassle. Either that or the ignition switch might be shot. There are a couple of sites online that tell you "how to replace an ignition lock cylinder" on Google. But do whatever. Just some food for thought..... Good Luck. Frasers73 06-07-2007, 01:19 PM You could just run new wires to the starter solenoid from the push button you're installing on the dash. The starter would still work if the keys weren't in the ignition, but the engine wouldn't start, unless you took power from a switched power source like your stereo power. Maybe not the best way - but you asked for the easiest! Good luck with it! Jon vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
