Remote programminglvella 10-24-2002, 12:44 PM I have a new remote for my '97 Sebring convertible. Does anyone have the instructions on programming? sebringstud 11-29-2002, 09:34 AM Yes.I have the remote instructions still...email me.. Sincerely, Ben (sebringstud) benthornburgh@yahoo.com boss2003 08-02-2003, 10:01 AM I also could really be helped with this info! Does any of you still have it?? mghill 10-13-2003, 01:03 PM Yes.I have the remote instructions still...email me.. Sincerely, Ben (sebringstud) benthornburgh@yahoo.com If you still have those instructions can you email me. I can't get my remote to program. :eek7: Thanks, Mickey mickeyhill@care2.com cadman455 12-29-2003, 11:39 AM Keyless Entry: Technical Service Bulletins Remote Keyless Entry Programming Information NO: 23-23-98 GROUP: Body DATE: Jun. 12, 1998 SUBJECT: Remote Keyless Entry Programming Information MODELS: 1995 - 1998 (FJ) Avenger/Sebring/Talon DISCUSSION: The listed models are shipped from the factory with only one key FOB transmitter. If a second FOB is added, it must be purchased through MOPAR and is not considered a warrantable item. Whenever a second FOB is programmed, the original FOB must also be re-programmed. If the original FOB is not re-programmed with the second FOB, the original FOB will not function. The following two procedures are available to program key FOB transmitters. Programming Procedures With The DRB III(R). 1. Connect the scan tool to the vehicle and power it up. 2. Select scan tool stand alone mode, current model year diagnostics, then body. 3. The screen will ask if this is a 95-99 Avenger/Sebring/Talon, select yes. 4. Follow the directions and prompts on the scan tool screen as follows: a. Close all doors, turn ignition key to off. b. Turn ignition key to Accessory. c. Turn ignition key to off, door locks will cycle once (in programming mode). d. For each key FOB, press any button 3 times in a row to program code. When programming is complete, the door locks will cycle once. NOTE: IF A SECOND KEY FOB REQUIRES PROGRAMMING, IT MUST BE PROGRAMMED WITHIN 1 MINUTE OF THE FIRST FOB PROGRAMMING. PRESS ANY BUTTON ON THE SECOND FOB 3 TIMES TO PROGRAM ITS CODE. WHEN PROGRAMMING IS COMPLETE, THE DOOR LOCKS WILL CYCLE ONCE. 5. The programming mode finishes after the following: a. Programming of two key FOBS is completed. b. One minute has passed since programming. c. Scan tool is disconnected. d. Ignition switch is turned on. e. Any of the doors are opened. Manual Programming Procedure (non scan tool) 1. Connect pin 1 of the 16-way data link connector to chassis ground or to pin 4 of the 16-way data link connector. 2. Close all doors, turn ignition key to off. 3. Turn ignition key to Accessory. 4. Turn ignition key to off, door locks will cycle once (in programming mode). 5. For each key FOB, press any button 3 times in a row to program code. When programming is complete, the door locks will cycle once. NOTE: IF A SECOND KEY FOB REQUIRES PROGRAMMING, IT MUST BE PROGRAMMED WITHIN 1 MINUTE OF THE FIRST FOB PROGRAMMING. PRESS ANY BUTTON ON THE SECOND FOB 3 TIMES TO PROGRAM ITS CODE. WHEN PROGRAMMING IS COMPLETE, THE DOOR LOCKS WILL CYCLE ONCE. 6. The programming mode finishes after the following: a. Programming of two key FOBS is completed. b. One minute has passed since programming. c. Pin 1 of 16-way data link connector is removed from ground connection. d. Ignition switch is turned on. e. Any of the doors are opened. Octoberfest 02-15-2004, 08:58 PM How do program the keyless entry remotes for my '04 Sebring Convertible Touring Edition, I want to add 2 to the 2 that came with the car. PhiDelt205 03-12-2004, 11:07 AM I am looking for instructions on how to program the keyless entry for my 1999 Chrysler Sebring. Can anyone help me out here?? I really dont have the time, nor do I want to, to take my car to the dealership. I appreciate any response. I can be reached at mholmes205@yahoo.com. Thank you. dsparks 03-12-2004, 08:55 PM Had a '99 Sebring Convertible 'til 3-10-04.Traded 4 Ford Ranger Pickup. Sebring had start and stall problem that my very honest christian mechanic could not find.Alot of people here are getting rid of their Chryslers. I won't buy a Dodge either. PhiDelt205 03-16-2004, 12:43 PM I got the keyless entry programmed for my 1999 Sebring, but now I have another question. Is there any way that I can make if so that the horn beeps and the headlights flash when I lock and unlock the car? I like this feature and I think that it makes it easier to let youy know when your car is locked and unlocked. I can be reached at mholmes205@yahoo.com. I appreciate anyones input. Thank you. tennis1mom 05-27-2004, 02:23 AM I have a question about the remote programming procedure. The instructions state that pin 1 should be connected to pin 4 or chasis ground. I checked and my DLC has a pin 4 which is ground, BUT it does not have a obvious metal pin in hole 1 visible from the outside. Is the pin recessed? To those who have successfully programmed their remotes - how did you do it? Nikolai382 09-28-2004, 06:37 PM I have a 97 Avenger and a remote that I need programmed for it. I have the manual for manually programming it but I cannot find the connector box that is supposed to be used. Can someone tell me where I can locate this? Thanks! Nikolai382@msn.com DC 95 Avenger ES 10-07-2004, 12:13 PM Will this work on a 95 avenger remote. Mine is the 2 button. Keyless Entry: Technical Service Bulletins Remote Keyless Entry Programming Information NO: 23-23-98 GROUP: Body DATE: Jun. 12, 1998 SUBJECT: Remote Keyless Entry Programming Information MODELS: 1995 - 1998 (FJ) Avenger/Sebring/Talon DISCUSSION: The listed models are shipped from the factory with only one key FOB transmitter. If a second FOB is added, it must be purchased through MOPAR and is not considered a warrantable item. Whenever a second FOB is programmed, the original FOB must also be re-programmed. If the original FOB is not re-programmed with the second FOB, the original FOB will not function. The following two procedures are available to program key FOB transmitters. Programming Procedures With The DRB III(R). 1. Connect the scan tool to the vehicle and power it up. 2. Select scan tool stand alone mode, current model year diagnostics, then body. 3. The screen will ask if this is a 95-99 Avenger/Sebring/Talon, select yes. 4. Follow the directions and prompts on the scan tool screen as follows: a. Close all doors, turn ignition key to off. b. Turn ignition key to Accessory. c. Turn ignition key to off, door locks will cycle once (in programming mode). d. For each key FOB, press any button 3 times in a row to program code. When programming is complete, the door locks will cycle once. NOTE: IF A SECOND KEY FOB REQUIRES PROGRAMMING, IT MUST BE PROGRAMMED WITHIN 1 MINUTE OF THE FIRST FOB PROGRAMMING. PRESS ANY BUTTON ON THE SECOND FOB 3 TIMES TO PROGRAM ITS CODE. WHEN PROGRAMMING IS COMPLETE, THE DOOR LOCKS WILL CYCLE ONCE. 5. The programming mode finishes after the following: a. Programming of two key FOBS is completed. b. One minute has passed since programming. c. Scan tool is disconnected. d. Ignition switch is turned on. e. Any of the doors are opened. Manual Programming Procedure (non scan tool) 1. Connect pin 1 of the 16-way data link connector to chassis ground or to pin 4 of the 16-way data link connector. 2. Close all doors, turn ignition key to off. 3. Turn ignition key to Accessory. 4. Turn ignition key to off, door locks will cycle once (in programming mode). 5. For each key FOB, press any button 3 times in a row to program code. When programming is complete, the door locks will cycle once. NOTE: IF A SECOND KEY FOB REQUIRES PROGRAMMING, IT MUST BE PROGRAMMED WITHIN 1 MINUTE OF THE FIRST FOB PROGRAMMING. PRESS ANY BUTTON ON THE SECOND FOB 3 TIMES TO PROGRAM ITS CODE. WHEN PROGRAMMING IS COMPLETE, THE DOOR LOCKS WILL CYCLE ONCE. 6. The programming mode finishes after the following: a. Programming of two key FOBS is completed. b. One minute has passed since programming. c. Pin 1 of 16-way data link connector is removed from ground connection. d. Ignition switch is turned on. e. Any of the doors are opened. quadis 10-27-2004, 12:08 PM Does anyone have fob programming instructions for '94 New Yorker 3 button FCC ID GQ43VT7T? Or, is it the same as the above? 69 Sprite 11-05-2004, 10:25 AM I changed the batteries in my remote for my '97 Sebring Convertible and then only the lock button worked. My manual gives instructions how to "synchronize" the remote and after doing that, the unlock button started working on the driver's side but the "hit twice" to unlock the passenger side door and "unlock truck" doesn't work. Must be there is a special programming exercise that has to be done to make this remote fully operable???? dgbboku 11-16-2004, 11:22 PM I have the same experience. Not Sure where pin 1 contact is??? Latif 12-11-2004, 09:47 AM Hi All, I have 1998/LE Sienna that I have just purchased a remote on eBay .I needed programming instructions. I have found some instructions on different Toyota models and years but they don't help me to work for 1998 Sienna/LE. Please any one would help me? I’ll be thanking this act of kindness. Latif vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
