Page updated on 06-22-2018
Cost of EGR Solenoid?
RicerKid15
05-23-2007, 07:59 AM
Is there a general price for the replacement of a EGR Solenoid and back pressure valve?
maxwedge
05-23-2007, 09:04 AM
Your kidding here? What year and car/truck?
UncleBob
05-23-2007, 10:15 AM
$1-1000
Hows that for generic :D
INF3RN0666
05-23-2007, 02:49 PM
haha, it's mean to make fun of people because they don't know any better.
For an EGR valve, you're looking at $200 plus or minus $50 for an OEM from the dealers. It's around $120 for after market.
INF3RN0666
05-23-2007, 02:52 PM
So you drive a mitsubishi 3000? I don't know the price for an EGR for one of those, but it's prolly more expensive. After all, if mitsubishi touched it, it's probably faster than all the other car parts :P. That must make it more expensive.
RicerKid15
05-24-2007, 08:02 AM
im drive a 1995 Nissan Altima...my check engine light wont go off and they are saying if i replace the EGR Selonoid Valve and back pressure valve to get rid of it.
INF3RN0666
05-24-2007, 09:21 AM
Man, the easiest way to actually find out the price is to call the dealership and just say "I WOULD LIKE A QUOTE FOR THE EGR OF A 95 ALTIMA". Then they will tell you something you won't like. Then you'll probably call some place that sells after market parts. I hate calling to ask about the price too, but it has to be done.
BTW, if there's anything wrong with your EGR, the car would shake while you're idling. The shaking would be worse when the car is warm.
UncleBob
05-24-2007, 11:09 AM
no....the engine light will come on if the EGR flow isn't within a narrow window....if it flows too little, or too much, it'll set off the light.
Altima 2.4L engines, by far the most common failure with the EGR system that I see, is the reference line from the exhaust port to the transducer deteriates and rips open. A 50 cent fix
INF3RN0666
05-25-2007, 07:40 AM
Well I learnt something there. Do you think that a similar line in my impala would be causing a misfire? There was a code for the EGR on my impala but the mechanic just said to replace the EGR. I figured it wasn't that simple, but who am I to argue with a mechanic? So I replaced it anyways, and the misfire is still there.. BTW, I still have the old EGR valve and it's sitting right beside me. It looks like new, that's why I was sketchy to replace it.
UncleBob
05-25-2007, 05:54 PM
your engine uses a much different EGR system...there's no vacuum lines, its all operated through solenoids mounted directly to the intake
INF3RN0666
05-25-2007, 11:02 PM
LOL you know your GM cars too well man. I should have known that considering I've seen the system hundreds of times.
UncleBob
05-26-2007, 12:14 AM
I'm just trying to help
