1991 olds bravadawendell37 05-22-2007, 09:02 AM no fire going to the fuel pump..... need to see wiring diagram..... can any one help?:banghead: MT-2500 05-22-2007, 10:22 AM A little more info would help. At fuel pump relay the pink/black wire is ign feed from ECM-1 fuse. Does it have 12 volts? The gray wire from relay feeds fuel pump. Does it have 12 volts on engine crank or key on fuel pump 2-3 second prime? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
