96 GMC Sierra 3500 shakes and vibrates
thunderstruck100
05-20-2007, 01:10 AM
I have a 1996 GMC Sierra 3500 Vortec 454, I have spend literally thousands of dollars of the last few years trying to have this problem fixed. When I am driving on the highway and hit about 100kph the truck starts to vibrate and shake. If I have a drink in the holder the truck shakes so bad it starts to spill. I have had almost everything changed in the last 2 years and it still doesn't run properly. You name it, I have it replaced or fixed, I have had my truck to about 5 different mechanics and they say nothing shows up on the scan. With almost everything replaced on this truck I am getting very frustrated. The shake starts at about 100kph and stops when you get to about 100kph. Has anybody else had this problem?
horse482
05-20-2007, 06:07 PM
Welcome to the forum. Have you checked the u-joints? The u-joints will cause vibrations at certain speeds.
maxwedge
05-20-2007, 07:08 PM
Pretty non specific question, how does this shake manifest itself, in the floor, in the st wheel, as an engine misfire, wheel/tire vibration? What was done so we don't recommend the same repairs.
thunderstruck100
05-20-2007, 07:34 PM
The dash shakes quite hard, I have repaired intake gasket, throttle body wiring harness, new plugs, new ehaust, all new sensors, fuel pump.
maxwedge
05-21-2007, 07:23 AM
Have the tires been check for being out of round, bent wheel, bad dr shaft u joints? Bent driveshaft or kinked? You say "everthing" has been replaced but from your description nothing pertains to the symptoms, has a mechanic driven this and suggested what the problem may be?
