2000 remote programming
Google
Web AF
matt96gt
10-21-2002, 09:39 PM
Anyone know how to do the keyless entry for a 2000 LE? It has the 3 button remote. TIA.
matt96gt
10-22-2002, 12:43 PM
OK, I found how to do it.
nicshow
12-01-2002, 12:50 PM
I just received an extra remote fob with instructions on programming...but I'm not sure I understand. What am I programming? Am I programming a receiver in the car to recognize that particular remote?
lojeti
01-01-2003, 12:37 PM
could you email me the instuction on how to do it. Email me a Lojet@tconl.com thanks
PSUlion01
10-25-2003, 03:59 PM
i'm looking for the instructions as well...care to share?
nicshow
10-25-2003, 11:15 PM
I can send you the instructions - if you'll send your email to me, I'll send it to you!
zmsaad
12-06-2003, 09:58 PM
any body care to share this instruction. Thanks.email at zmsaad@yahoo.com. Thaks
sski
12-07-2003, 08:43 AM
I am also in need of the instructions of you wouldn't mind sending them one more time.
sski@gte.net
Thanks in advance!
Steve
rlamb01
12-20-2003, 06:26 PM
I'd like them too
rlamb01@yahoo.com
Breadman
12-26-2003, 08:26 PM
Please send me a copy to.......Thanks.........Buddy.
bmgriffin@bellsouth.net
jianx23
01-31-2004, 02:15 PM
Please email me a copy of the programming instruction.
2000 Camry LE remote
Greatly Appreciate!!!
jianx23@yahoo.com
James
mm1997
02-02-2004, 09:24 AM
will they work for a 97 camry?
Breadman
02-02-2004, 03:08 PM
Hello
97 model is not the same...but if you will look all over this camry site you will find something on the 97 i'm sure. Good luck.....Breadman
.............STILL LOOKING FOR HELP ON THE 01............................
mm1997
02-03-2004, 07:59 AM
I found this for a 2001.........Still need help on my 97...........
Here it is?
2001 Camry Keyless Remote Programming
1. Start with
a. No key in ignition
b. Driver's door unlocked
c. All other doors locked
d. Driver's door open
2. Insert key into ignition and remove
3. Press lock, pause, unlock (2 second total cycle) 5 times
4. Close, then open driver's door
5. Repeat lock, pause, unlock cycle 5 additional times
6. Insert key into ignition and turn from lock to "on" two
times (pause in
each location 1 second). (note: "ON" not accessory position)
7. Remove key from ignition
Locks should cycle twice. If not, start over.
8. Press lock and unlock buttons on transmitter
simultaneously for 1-2
seconds then release
9. Press lock and unlock buttons on transmitter again
simultaneously
for 1-2 seconds then release
10.Press lock alone for 1 second, then release
Locks should cycle once
11. Close Driver's door to exit program mode.
If you want to program more than one remote, repeat steps 8 - 10 with the second remote before finishing with #11.
niwre
02-17-2004, 05:21 AM
i plan to purchase a keyless entry for my 2000 camry. can somebody help me to give me points to consider when purchasing a keyless entry device? What should i look after?
And can you also send me a copy of the instructions just in case? erwindxb@yahoo.com
Thank you very much
Breadman
02-17-2004, 01:12 PM
Look on ebay, thats the best place and the best price.
...........................Breadman............... ...................
Breadman
03-03-2004, 06:34 PM
Hello MM1997
Thanks for the instructions for the 2001 camry keyless remote.
It worked perfect..........THANKS MAN
P.S.The dealer wanted 39.95 for each remote and said it would take about a hour. My wife read it off and i did the codes and it took about two minutes........THANKS AGAIN :iceslolan :naughty:
Google
Web AF
