Pull out Car Radio unit from 93 Camry sedan
Google
Web AF
summerhill
05-14-2007, 11:15 PM
My car radio has problem, and I have to fix it or install new one. Does any body give me any ideas how to pull out this unit? I don't have service manual
Thanks!
Brian R.
05-14-2007, 11:28 PM
There is a 1994 FSM linked in a sticky post at the top of this forum. The procedure should be the same as that shown in that manual.
Mike Gerber
05-15-2007, 03:07 PM
Pull the u-shaped cover from the dash. There are 2 clips that hold it in at the bottom on both sides. Pull out from there. I find a j-hook tool or a dental pick works well here. Then you just undo the top portion of the u-shaped cover by pushing in slightly and down. At the top it hooks a bit under the upper dash panel. Then there are 4 screws that remove the radio and cage assembly from the dash. They are usually a special phillips hex washer head screw. Either a phillips screwdriver or a nut driver works fine. Once the 4 screws are out you pull the radio out a bit and remove the 2 modular connectors from the back of the radio along with the antenna connection. You can then unscrew the radio from the sides of the cage and take it out.
Mike
Google
Web AF
